coolmom42's avatar
coolmom42
Explorer II
Aug 14, 2016
Looking for a 4000 lb (or less) TT
After much dithering & thinking & number crunching, I've finally decided that my "retirement rig" needs to be a SUV (Highlander or Explorer) with 5000 lb tow package, combined with a traditional hard-side travel trailer of 4000 lb GVWR or less.
I like a front bed/rear bath layout, with a mid kitchen. So far I've found these candidates:
Jayco SLX 145RB with unloaded wt. 2330, GWR 2995, cargo 665. Fresh/gray/black capacities of 10/15/9 gallons.
or the
Amerilite 14RBC with unloaded wt. 2230, GVWR not given, cargo 1050. Fresh/gray/black capacities of 30/36/36.
Can I assume that GVWR of the Amerilite is the total of 2230 + 1050 = 3280, even though it's not explicitly listed?
Does the the GVWR of the Jayco imply that it is on a less sturdy frame?
I was partner in an Amerilite (21MB) for a few years, and was pretty happy with it. Have no experience with Jaycos, but have friends who like theirs.
The Amerilite is a few inches taller inside, which is good for a person who is 5'10".
I'm also NOT a fan of the small tank capacities of the Jayco. 10 gallons of fresh water is pretty lame.
For sure travelling with all the tanks full would use up most of the cargo capacity of the Amerilite, but no reason to do that.
Does anyone have input on either one of these specific trailers?
Any other rear-bath layout small trailers that you could recommend?
  • danimal53 wrote:
    Coachmen Clipper 14r has 33gallon fresh tank, and same layout as the two you mentioned.
    clipper 14r
    you can go slightly longer than 14 and still be under 4,000lb, there are 16-17ft that have a fixed bed instead of using the dinette bed. Clipper 16fb or 17fb.
    Thanks, I like the looks of those!
  • Coachmen Clipper 14r has 33gallon fresh tank, and same layout as the two you mentioned.
    clipper 14r
  • Take a look at the Forest River R-Pod RP-180.
    We had an R-Pod and loved it until we decided we wanted a walk-around bed and dry bath.
