Campingliz99's avatar
Campingliz99
Looking for a new trailer
Hi RV experts! We have been using a 17 ft hybrid, then a 25 ft class c for about 11 years each ( yup, 20+ years of RVing with 5 years of tent camping first.)
We are ready to go back to a hard sided trailer. There are just the two of us now. A few things we would like:
Walk around queen or king bed - always a bed
Dinette
Separate doors fridge and freezer
Lots of storage
Dry bath
Built in generator for the a/c
Any suggestions? Thanks in advance!
Liz
  • Walk around King or Queen bed?
    Wanting the bed to stay a bed? Sounds like a "separate" bedroom layout..
    Pretty rare in TTs, better chance of finding that in 5th wheels or extremely long TTs (30Ft+)..
    Yrs ago were were looking for a Queen (not walk around) in a separate bedroom with real wall and door.. Only found that setup in 32ft+ TTs.. Never found any "walk around" Queen beds in TTs.
    As Huntingdog mentioned, gens in TTs are pretty rare, Toy hauler or 5th wheel might be your choices..
    Toy Hauler, you could use the "garage" area and convert that to a Master bedroom with your walkaround King/Queen bed..
    Downside to Toyhaulers is that they often have a very heavy tongue weight empty because when you put bikes/quads/golfcart in the garage the tongue would be too light and under 10% TW when loaded. So, you will need a tow vehicle with sufficient available cargo weight to handle the heavy tongue..
    Dinette
    Lots of storage
    Dry bath
    Liz
    Consider a toy hauler. TTs with built in Generators are RARE. And the few I know of are Propane only. If your main concern is the AC, then I would recommend a gasoline generator. Using a propane generator to run the AC has a big problem. They use a lot of propane. Since you would be using it for long periods powering the AC, you would likely run out a lot.
    Toy haulers with generators usually have at least one gas tank. Some have two. My TH has a 30 gallon tank for the generator, and another one for the toys. I did a modification to the tanks plumbing that allows me flexibility to use the gas in the tanks for either the generator or the toys or both as I need it. Without toys, that could mean a lot of generator runtime for you.
