spud1957
Sep 23, 2014Explorer
lenr wrote:
I sympathize with the OP; I don’t know what I would do if my Ford let me down. At 44,000 mi, our F-350 SRW CCSB 6.7 has been perfect (knock wood) with excellent mileage for a modern emissions truck.
A few additional thoughts:
1) I used the “picture frame” adapter and it put the nose of our trailer 2 ½” too high with no adjustment available. Had to change to the elite hitch.
2) If the OP is concerned about Ford fuel mileage based on his 6.4 diesel, that engine was TERRIBLE on fuel. That is completely fixed with the 6.7 engine which gets as good a mileage as any and weighs more (stronger, more steel) than some.
3) All three brands use a HP fuel pump made by Bosch. All are susceptible to pump problems with anything having low lubricity. Best way to avoid problems is to buy fuel from high volume locations and to use additives that add lubricity. Ford has made the news because they sell the most and seem to be a little prickly at denying warranty if there is any evidence of water (no lubricity). The actual failure rate is 6 in 10,000 and part of those are covered by Ford.
4) As stated by others an F-350 would solve the sagging problem, while coming with heavier axle internals, and auxiliary spring, an 4” spacer block (which can be put on a 250 to solve sagging problems), and a VIN that lets one tow more weight legally.
All great points but to clarify point #4, the F350 and F250 have the same "axle internals". The aux spring is standard on the F350 and 4" blocks are the only physical differences between the two
44,056 PostsLatest Activity: May 04, 2014
