Ladderco6's avatar
Ladderco6
Looking for expert advice on TV/RV size and weight
Hello all,
The wife and I are starting to look at our first TT and decided that before we go any further we look for some advice from some experienced RV'ers. I have driven tractor trailers for many years so I have a lot of experience driving, but the weight to trailer/ truck size can get confusing. I own a 2012 Ford F150 FX4 short bed without max tow, but I do have have a standard tow package wirh factory trailer break installed. other specs include Ecoboost motor 3.73 gears with a load weight of 1135 lbs. Truck GVWR is 7200 lbs, GCWR is 15,500. What would be the MAX comfortable tongue weight and trailer length/ weight you would recommend? I' currently looking at 600lb hitch with a 5995lb dry weight total weight 7600 lb trailer that is 29' feet long.
By the way it's just the wife and I in the truck.
Sorry for the long question but the people here seem to be the best to ask this question to!
  • IF your payload is really only 1135 lbs. Then that trailer is too heavy. Your loaded tongue weight will be over 900lbs.
    Personally that payload sounds really low. Go weigh the truck, and subtract that weight from the 7200 lb GVWR of the truck. That is your payload. It's hard to believe a 150 has a curb weight of 6100 lbs.
  • Your proposed numbers sound really good to me. You have left yourself plenty of room between the dry weight and the more realistic loaded weight so you should be fine with that type of combo. Just make sure that you are using a properly setup WDH and sway control to keep everything balanced and in check.
