valhalla360
Aug 02, 2016Navigator
The air/con controls the discussion.
On startup, it will typically need 2-3times the rated watts, so that puts you into the 2000watt portable generators.
Also, if the battery is low, the converter can demand quite a few watts until the battery gets charged. One option would be to install a switch, let the air/con start and then turn on the converter once the startup load drops off (which is within a second or two).
44,029 PostsLatest Activity: Jan 13, 2025
