getpower1
Mar 20, 2016Explorer
1handyhubby wrote:
I'm looking at fords - F350 v10 dually between 1999 and 2005 and am wanting to know which performs better and holds up better, automatic transmissions or 5 speed manual transmissions. I'd appreciate y'alls opinions and experiences. I have an 11' 3" Lance but am looking to getting a Bigfoot with a slideout. I'd apperciate anyone with a 4x4 to weigh in too. Thanks.
Now, to expand on years and transmissions...it was a ZF-6 for the manual. It's a 6-speed technically speaking. I had one in my 1999 7.3. It's a really nice transmission as far as any manual transmissions go. ZF transmissions are very tight. These were used in all "super duty" trucks until they stopped offering manuals at all. Now, driving it, it's pretty much a 5-speed. First gear with 3.73s and 35" tires was so low that I couldn't shift out of it until I stopped. Started in "2nd" all the time. There are quotations because they called 2nd 1st. Shift pattern was "R", then straight down was "L", after that it was 1-5 like a normal 5-speed. But your reverse was toward you and up instead of away and down.
The 4r100 was the "super duty" automatic for the 7.3 years. It was not a bad automatic. People don't give it enough credit. It was rated for more weight than the truck could pull when stock. Transmission maintinence isn't on everybody's scheduling. The 5-speed torqshift is a really nice transmission. The grade shifting is really awesome if you haven't driven a truck with it. These came with the 6.0 year trucks. 7.3 was 1999-2003. 6.0 was half way between 2003-2007. I'm not sure on the particular specifications of the two automatics, and I am not sure what year or when they went to the torqshift on gasoline models.
As far as "holds up better"...that depends on a lot of things. What terrain you'll drive, what your gross weight will be while driving it, how often you'll drive with that weight, wether or not you want to shift or care.
If you want the opinion of a city truck driver...shifting is a pain. But I still have a truck with a stick and I put a lot of miles on it. Have a friend who's dad has a v10 2002 f250 for work. Doesn't tow at all, but I know it has. It's got well over 250,000 on it with the original 4r100.
I can say more, but I'm not sure what the relevance would be. What would you like to get? Do you want an auto, and are asking about a manual because people say they are more simple and cheaper to buy a clutch for, or do you want a manual and want to hear it'll be fine? I'll say this...if you don't mind shifting, then whatever you find will work great either way.
