Bedlam
Jun 21, 2014Moderator
With the camper on the truck, you will be 8' wide with or without dual rear wheels. I suggest getting the truck with the most rear axle weight capacity you can afford. If you had a truck you wanted to keep (like I did when starting with a TC), you will be more limited in your TC choice and will have put more upgrades in your truck. This also applies if you get a truck that is just enough for the current TC you want to buy - What happens if needs or wants change requiring something bigger?
I currently am set up well on a SRW truck pulling a heavy load, but I cannot add anything else to the rear of the truck or go to a bigger TC in the future. For us, we will see a bigger double or triple slide TC in the future and I dream of a stacker trailer in tow one day.
44,056 PostsLatest Activity: Nov 19, 2013
