BarabooBob
Feb 03, 2021Explorer III
Remember that the bigger the TT gets, the more complicated it gets. Tandem axles equal twice as many tires, and hubs. Slides could mean troubles with slide mechanisms, leaks in the slide seals, and possible troubles using the interior unless the slide is extended. If you are planning on camping in the national parks, you can be limited to shorter TT's.
My wife and I started with tents, went to popups, small Class C, and are on our second TT. The current TT will be around a long time because we like the fact that the dining area is like a green house. It is mostly windows on entire rear. It also tows very well because it is a single axle 17' unit. We don;t need more room because we spend most of our time outdoorsunless we are sleeping or it is raining or really cold.
