Curly2001
Apr 07, 2021Explorer II
Please make sure with whatever you purchase, has a tow package with a good rear end ratio. I have been through this with a Tahoe with a 3:23 gear ratio and burned up the rear end. I do feel the Tahoe with the properly rated rear/front diff, will do a fine job. I had my diff ratio changed and it pulled very well with no issues. I am sure you can find one with a tow package but check on the rear end ratio before you pull the trigger on it. It is very important for towing. Also, the size of the Tahoe or whatever you look it is important in towing that you don't get a tow vehicle that is so small or narrow that you can't see around the trailer that you are towing.
Good luck,
Curly
Good luck,
Curly
