Reddog1 wrote:
Not much gain with the 225's, and the wheels (7.5) are too wide. I do not know if the 265's are too wide for the 7.5 wheels. I suggest you look into the wheel with for a given tire size.
My truck is a 1996 Dodge 2500 2WD. I went with Michelin Mud&Snow 245's about seven years ago. I think they cost me just under $400 each. I have had no issues with them at all. they do sing, or did, but I adapted to the singing. I definitely have a stiff ride with an empty truck. I got used to that as well.
The 19.5's will definitely reduce the sway due to heavier sidewalls.
Wayne
Why would Vison wheels make a rim that does not have a range of tire options? 19.5 7.5 is the only size they offer for that wheel. It is the size Rickson sells also.
You do realize the 2500 has single tires all the way around?
