burningman
Jan 21, 2018Explorer II
Most guys here think only new $50,000+ trucks are able to carry anything.
I went lots of miles over mountains in trucks that weren’t worth more than $5k and were loaded to 12,000 and towing another 10,000.
The early 5.9 Cummins will not quiet down with a muffler. Most of the noise is the engine itself, not the exhaust.
My Spidey-sense tells me anyone with a 500-hp 5.9 has some amount of mechanical knowledge and can handle an older truck that might need something freshened up here or there.
At that budget, gas is definitely the only option especially with an automatic trans. The diesel/auto you’ll get for that will probably need a fairly expensive trans real soon, or fairly expensive something else.
They’re getting hard to find now, but those old “square-body” Chevys (‘73-‘87) are really good trucks.
When you’re dealing with an older and cheaper truck, you really want pre-electronic era stuff.
I’ve also got a high-powered hot rod early Cummins one ton, I planned on “offing” my old Chevy but I just can’t, that thing ALWAYS runs and if it did fail, nothing on it is expensive or difficult.
The two wheel drive models (if that’s an option) drive really nice even when old and worn. Clean nice ones do still exist, and everything is available for them. I just GAVE AWAY a fairly decent 2WD crewcab dually Chevy that needed a motor (ANY GM V8 goes right in, it started as a 6.2 diesel and I’d had 455 Olds and 500 Caddy engines in it) just for having the kid who wanted it haul out some junk from my rental house yard.
I’d be a little sketched-out about buying an old and cheap computerized-era truck.
I think you need to stay with something super cheap to fix, the problem you run into with older trucks is finding yourself with a problem that costs more to fix than the truck is worth.
I’m also a bit curious, why NOT just use your Dodge?
My daily-driver car was lost to an accident three years ago and I just started driving my truck instead of replacing the car. Seemed to make more sense.
44,025 PostsLatest Activity: Feb 18, 2025
