Fireballsocal
May 01, 2017Explorer
I went with the MORryde small mount. It has an articulating arm, a solid lockup, and is well built. It's on the upper end cost wise though. It does swivel up and down however you need to loosen 2 wingnuts for that function. I replaced the included hardware with larger bolts as I through bolted mine through an interior wall. It's a sturdy, well designed mount. My only issue was that the television I bough didn't have a smooth back so I needed to create some spacers so the TV mounted flat. That was more because of my cheap television than any fault of the mount. https://www.amazon.com/MORryde-TV1-025H-Extending-Swivel-Mount/dp/B00AZS8PMM/ref=sr_1_6?ie=UTF8&qid=1493658818&sr=8-6&keywords=rv+television+mount
