carringb
Jul 27, 2014Explorer
Here's why I like the Northwood/ORV trailers:
-Everything is put together well
-Most appliances are upgraded from standard fare (i.e. larger water heater, bigger oven, bigger fridge)
-Full aluminum body framing, with wood embeds in the framing for attachment points, so the screws won't pull through
-They use screws instead of staples
-Outside kitchen has a proper 3-way fridge.
-Bigger tanks. Mine holds 103 gallons of fresh water.
-4-seasons rated (good insulated and fully insulated water systems)
-Beefy chassis with proper gusseting at suspension points and shock absorbers.
-Good year tires, Load Range E on the bigger units, or at least Ds on the mid-size trailers.
44,026 PostsLatest Activity: Mar 01, 2025
