Travel4Life wrote:
I'm looking to buy my first TT in a few months. I am waiting to buy a tow vehicle until I pick a trailer but right now looking at a tow capacity of 9000. I have four kids and looking at quad/tri bed bunkhouse options (Outback 322BH, Jayco, Shadow Cruiser 280QBS as examples). I've been out looking for a few days and wondering the forums but I want to ask -
What do you wish you knew while shopping for a TT the first time?
What easy mistakes should I avoid?
I'm afraid of sinking tens of thousands into a poorly made lemon only to regret it later - but it's hard to tell build quality as a novice - what should I look for?
#1 mistake, "buyers remorse" AFTER the paper work has been signed and after realizing RVing is not for you..
OR..
Bought too big or heavy of a trailer for your vehicle..
OR..
Bought too small of a trailer for your family..
OR..
Decide you do not like the color, shape and or layout of the trailer..
OR..
Can't afford the purchase..
Or..
So on..
Since it is your first trailer, I would recommend renting a RV and do a trial camping "trip".. See if you actually like camping.. Some folks after buying a RV end up finding out it is not for them.. That is a huge expensive mistake.. Renting once or twice is a very cheap way of dipping your toes in without having a $20K+ RV sitting in your back yard for nothing.
Additionally, some folks find out they don't like a layout or trailer size.. Once again a very expensive mistake.. You WILL LOSE MONEY if you trade or sell off your trailer..
Then when you have rented a couple of times consider attempting to tow a trailer.. If you have never towed anything rent a Uhaul trailer and tow it around for a day.. Towing changes a vehicles driving characteristics.. Some folks may have a hard time getting used to having something attached behind their vehicle.
THEN, consider buying a USED trailer.. Buying a 3 or 4 yr old trailer for much less money allows you to cheaply determine what you like/dislike in a trailer layout.. Much of the depreciation hit was taken by the previous owners and you can sell it off for very little loss..
THEN once you have your likes/dislikes and needs figured out buy a new one that more suits you..
And last of all, as others have mentioned, find out the exact cargo payload of your vehicle is.. Most chances you will run out of cargo payload before you reach those "towing ratings"..
Your tongue weight and weight distribution hitch become "cargo" of your vehicle. So, it is important to understand that your cargo weight of the tow vehicle plays an important part in just how much can be towed.
Your bumper pull trailer tongue weight MUST be no less than 10% of the trailer weight but it is typically 10%-15%. Ideally the more tongue weight you have the more stable the towing (going under 10% is dangerous and makes for very unstable towing), leaning towards 15% is best for bumper pull trailers.
To put tongue weight into simple terms for just how much your cargo weight can tow..
5,000 lb trailer should have a min of 500 lbs (10%) but may be as much as 750 lbs (15%) not including weight distribution hitch so you would want to make sure you have around 800-850 lbs of cargo left on your tow vehicle.
6,000 lb trailer should have a min of 600 lbs (10%) but may be as much as 900 lbs (15%) not including weight distribution hitch so you would want to make sure you 950-1000 lbs of cargo left on your tow vehicle..
Yeah, there will be lots of "dissenters" on this cargo weight theory but for your first try it is better to error on the LIGHT side instead of finding out you NEED a vehicle with more capacity after buying a RV..
