SoundGuy
Mar 20, 2016Explorer
Jetta03 wrote:
You might want to confirm the weight of that trailer. Winnebago shows that one to have a gvwr of 7000lb which is over your tow rating. The dry weight of 3700lb is a fictional number based on the empty trailer with no options, you will likely find yourself much closer to the gvwr.
Let's be realistic - the OP would at most see this particular model's GVW, loaded and ready to camp, land somewhere in the 4700 to 5000 lb range (just as I previously detailed) and nowhere near it's GVWR of 7000 lbs. This is a classic example of why it's a poor idea to rely solely on any rig's published GVWR to determine if the vehicle in question can safely tow it.
