valhalla360
Aug 04, 2022Navigator
Might be an issue if traveling as you need to open the slide to access the bathroom or if you are doing a quick overnight at walmart and can't open the slide, you can't get to the bedroom.
Once set up on a site, looks fine.
There is very little difference in quality between brands. Personally I prefer the aluminum exterior. If you go around an RV park, it's rare to find a 5yr or older fiberglass sided unit without bubbles where it's delaminated.
