Huntindog
Sep 26, 2016Explorer
hohenwald48 wrote:I blew up the pic... I could make an argument either way. Best to hit them all with a torque wrench just to be safe. As I said before, they do tend to loosen as the spring pack seats... What I find interesting is that I usually only see that once on springs.. Wheel studs can take several tightenings before they settle down.Huntindog wrote:hohenwald48 wrote:Huntindog wrote:DanKirk wrote:We have a winner. I have done a LOT of spring/shackle work over the years. Those are standard shoulder shackle bolts. That way the spring is left free to move as it should....
I believe the bolts are shouldered bolts. I bet the nuts wont tighten any more, they are tightened all the way to the shoulder of the bolt.
Ditto this. It's difficult to tell in a picture but all the visible shackle bolts appear the have the same amount of thread showing so it is likely they are all tightened down against the shoulders. However, the U-bolt nuts are clearly not tightened properly.
The U bolts are probably fine. They are often not centered when in the bending tool perfectly... This pic appears like that. If torqued properly they will work fine... However, I have found that it is a good idea to recheck these soon after installation. They often lose some tightness intially, then are fine. I think it is the spring pack settling together the first few miles.
I don't know about those U bolt nuts. The one closest to the camera looks to be about 1/8" up off the top plate. Hard to tell for sure.
44,071 PostsLatest Activity: Aug 30, 2026
