Lynnmor
Sep 27, 2016Explorer II
hohenwald48 wrote:Lynnmor wrote:
. . . my trailer came with cheap metric steel shackles. To elaborate on that, it was 5 mm thick steel (.196") but the bolts and springs are sized for 1/4" (.250") thick shackles. The result is .108" excess clearance, that is nearly 1/8 inch and might be what we see here. . . .
That .108 excess clearance is on both sides of the spring too. That comes out to .216" in excess clearance. Almost a full 1/4" excess.
No, I took that into account. There is about 1/16" clearance designed in the assembly, and the springs are made to a minus tolerance. For example; if you have springs that are -.015", the .062" design clearance, and the .054" undersized shackle on each side, the result is .185" slop. I made new parts from better steel, altered the bolt lengths and used good locknuts, giving me .040" total working clearance.
Look at how the cheap locknuts locate on the bolt shoulder when tightened, and you will see one reason why I replaced them.
44,071 PostsLatest Activity: Aug 30, 2026
