towpro wrote:
Lantley wrote:
The technology exist to resolve this issue.Get a trma level check. To easily check your LP level. They are not cheap but they are cheaper than losing a fridge/freezer full of food.
Thanks Lantley. I just bought the one Dometic stamps there name on from Amazon for just over $32.00
click here
I paid a couple $ more and bought it direct from Amazon so if it don't work I can return it no questions asked. I do maintain 8 LP tanks between RV's and grills, maybe this will make it easier.
I'll just note that I have the Domestic. First one I got rattled and didn't work because the "cages" which hold the battery were loose. Second one worked but I just dropped it in the dirt and sure enough the batteries are loose again. I may try and re solder them but not sure it will work. I suspect the Truma is much better made.
