We have a heartland mallard m29. It has the wide track wheels. It is very loud when turning especially. Is this normal. Looked under Neath at the axles nothing seams to be wearing. Only been at this a...
The squeaking sounds are from the spring shackles. The plastic bushings wear out quickly and it is steel on steel. I added wet bolts to mine(7 each side) and after they were greased,all noise went away.Trailer tows thru campgrounds quietly now. bolts are only about $6 each
