kohldad
Apr 15, 2019Explorer III
I don't understand the splashing except when the system is first purged of air. To prevent the splashing during purging, just open the faucet before the pump is turned on so there isn't any pressure. Once the air is removed, the water flow should be smooth and only at the volume the faucet is turned on which should be fgrom a trickle to wide open.
Full psi should only be found before the faucet handle so it really doesn't matter if you are using a 50psi or 20psi pump. The difference is only how much water can be pushed through the faucet.
If the splashing is occurring at other times, please explain when it occurs.
44,066 PostsLatest Activity: Mar 14, 2015
