Kayteg1
Apr 15, 2019Explorer II
Try to understand hydro-mechanics behind water pump.
All TC water pumps have pressure switch and since you use it for small faucet only, it is the pressure, not the flow that makes the splash and 50 psi will be more prone to splashing than 35 psi.
The $29 Seaflo has decent reviews, so sure sounds like good choice.
They don't list weight, but should be lighter than high-capacity pump as well.
Add that lower pressure = less noise to pump.
44,066 PostsLatest Activity: Mar 14, 2015
