- PoolExplorerMay be the issue that I have suspected for a while why the heater will not fire.
- DiskDoctrExplorer
Pool wrote:
Has anyone had low LP pressure but still liquid in the tank? Can it build pressure by bringing inside to warm up?
Yes. When the temp drops outside, the smaller tanks can't always keep up with demand. The regulator is more prone to freezing up, too.
And, of course, the regulator could be bad.
Grilling in the winter, we have brought the 20lb tank inside the garage overnight before use. - ChooChooMan74ExplorerIf it is a cylinder and not a tank, the OPD valve may be stuck. Bang it a few times on the ground. My 5 pounder has does it when it is filled on occasion.
- Old-BiscuitExplorer IIIBad regulator or Bad pigtail hose from tank to regulator
The output of regulator is only 4/10ths of 1 lb of pressure per square inch (0.4 psi----11" Water Column)
Propane will flow at -20*F and lower
44,054 PostsLatest Activity: Dec 17, 2025
