RickW
May 24, 2022Explorer III
1. Most of the weight is on the front jacks. When you raise one of the rear jacks, the other will come off the ground. The jack you raised is temporarily holding the rear weight. Raise the other one just enough to have both jacks on the ground and go back to raising the front ones a few inches each.
2. It is recommended that you keep the camper level or with the front a few inches high when raising and lowering the jacks. Don't do it on sloped driveways.
3. Get a portable drill that is at least 12 volt (preferably 18 volt) and has 2 speeds. Use the lower speed with the higher torque.
HINT: Watch where the drill is in relation to your head. When your fingers slip off the detents and the jack screw suddenly locks, you can get a headache real fast (or so I have been told :o)
