edgerelease's avatar
edgerelease
Lowering / raising with manual jacks
Just bought a 2022 Palomino HS 8801 for my 2015 RAM 2500. (Added Timbren bump stops but that is a different topic). Love it so far, but one thing I am absolutely HATING is that it did not ship with electric jacks. It is pre wired for them and should have but with supply chain issues they are VERY hard to find.
I've taken it off and put it back on once for practice. Looking for advice, with safety first and foremost, on technique. I raised (and lowered) each jack no more than 4" at a time and used my level to make sure things were steady. Kept the front a bit higher at all times. One of the legs would come completely off the ground each time I did this. Is that alright? I could probably adjust each jack by like an inch or less to avoid this but that would take FOREVER!
Gotta say, I was nervous getting that thing high enough to load on the truck! I don't care what the weight rating is on those jacks it is sketchy.
Thanks for any thoughts. Oh, and if you know of any electric jacks available let me know ASAP! Can't get them anywhere.
  • edgerelease wrote:
    Thanks monkey44. I have the connector but my drill may need to be upgraded. It quits once things get really heavy. Was more concerned about the lifting leg so thanks for the comment.
    I bought a heavy duty Makita - battery powered - it lifted my Fleetwood at 2500 lbs. easily.
    BTW: Lift the front two first, then the rear, in three or four inch increments each.
  • Personally I would take it easy and raise or lower just a couple of inches at a time. Or you could get a partner with another drill and raise the front several inches before switching to the rear jacks.
  • Never had manual jacks, but the ability to lift or lower one end or one side (2 jacks at a time) is invaluable in keeping it stable (and quicker, lol).
    If you can employ a wife/helper etc and have 2 drills or hand cranks or whatever, it would be preferable IMO.
    Strange you could get it to pick a front leg, but good, I mean great, as it's pretty well balanced for loading (most TC's will 3 leg and pick a rear leg no problem, but most wont float a front leg due to center of gravity)
    Idk where to find jacks, but good luck in your search and happy camping with your new camper!
  • Thanks monkey44. I have the connector but my drill may need to be upgraded. It quits once things get really heavy. Was more concerned about the lifting leg so thanks for the comment.
  • Get yourself a heavy duty battery-power drill and a connector ... when I had a camper without electric jacks, I'd raise it three or four inches at a time, no problem.
    Even with electric jacks my current camper sometimes raises one leg quicker than the others. I just stop and balance the jacks out individually, then continue.
