ohiopicker's avatar
ohiopicker
Lowering my 2013 RAM 2500 4WD
As many have pointed out, the new pickups' beds are much taller than they were a few years ago. This often puts fifth wheel RV's in a nose-high posture.
My previous TV, an '04 Ram 4WD had riser blocks between the rear springs and the rear axle seat. I was able to remove the risers from this position and place them on top of the spring pack, which allowed me to reuse my U-bolts. This lowered the rear of my truck by about an inch and a quarter.
My 2013 also has these riser blocks. Has anyone here done the position swap that I described above on a newer RAM? If it' still an easy fix, I'll be doing it on the new one, too.
  • Road Ruler wrote:
    gmcsmoke wrote:
    I'd raise the trailer before I lowered the truck.
    Yikes..... As a TV, one of the shortcomings of a pick up is the high centre of gravity. Raising the trailer to match is also a no no which reduces handling performance. Two wrongs don't make a right.
    A lot of people have done it without harm. It is done by relocating the spring pack to the top of the axles.
  • Before you mess with the truck check with your dealer about the warranty if you alter your veh. They do get pickly sometimes.
  • Because there is nothing uglier than a lowered pickup truck, and it will be front high when a load is on it making it look even worse. Just my opinion though
    Why? Seems like that would involve a lot more work. How does one raise a trailer, other than fabricating a sub-frame under the trailer to which the springs are attached?
  • 45Ricochet wrote:
    Mine is 58.5" to the top of the tailgate but will squat ~4" when hitched. A DRW 2013 is about the same height but not sure about the squat since most everybody hasn't been able to hitch up yet :E because of the lack of hitches.
    Mine only squats about 1 1/2 inches, measured at the tailgate when I hook up my Laredo 27RL. I designed and built my own mounting brackets to mount my in-bed rails. They worked out really well. I'd post pics, but haven't figured out how to do that yet.
  • Mine is 58.5" to the top of the tailgate but will squat ~4" when hitched. A DRW 2013 is about the same height but not sure about the squat since most everybody hasn't been able to hitch up yet :E because of the lack of hitches.
    The squat factor or final height will be interesting to me as I'm about out of pin box and hitch adjustments. I have heard the 2014 will have rear bags which would certainly help adjust a load or trailer.
