Super_Dave
Feb 24, 2019Explorer II
Lowering my dually?
Does anyone know of an easy way to take 2" out of the bed height on my 2006 Ram dually? Would it create a domino effect to other suspension system changes?
Grit dog wrote:wnjj wrote:
Driveline angle doesn’t matter, it’s the angle of the pinion that needs to match the angle of the transfer case output shaft. If the suspension is lowered In a way that keeps the rear axle unrotated compared to its original location it should be fine. Changing the hanger length on one end of a leaf spring can cause issues. Removing blocks between the axle and springs should not.
This is also a consideration, but not typically with "small" adjustments such as this, like you pointed out.
