Super_Dave
Feb 24, 2019Explorer II
Lowering my dually?
Does anyone know of an easy way to take 2" out of the bed height on my 2006 Ram dually? Would it create a domino effect to other suspension system changes?
Bedlam wrote:
Changing axle height changes the drive shaft angle between the transfer case or transmission and the axle. This anle will be exaggerated even more once the rear loaded down. The OEM accounts for loaded and unload ride heights when designing the drive line angle if you go too far out of specification, it will cause joint issues. if you look at some suspension lift kits made for trucks, they will actually have a wedge that is inserted between the axle and springs to lessen the joint angle after adding the lift. You can argue that this is more of an issue in the front to due to a shorter run, but it also happens in the rear.
Read up on proper pinion angles and drive line vibration before dismissing what happens when you change ride height.
