Super_Dave
Feb 24, 2019Explorer II
Lowering my dually?
Does anyone know of an easy way to take 2" out of the bed height on my 2006 Ram dually? Would it create a domino effect to other suspension system changes?
Bedlam wrote:
It will change your drive line angle. If you are getting considerable squat from your load plus lowering axle height you may find u-joints failing under heavy load or joints binding during spring compression. Lowering the rear too much without adjusting the front may make the truck nose high when loaded - This will affect your steering and lighting.
parker.rowe wrote:ACZL wrote:
I removed the aux spring hangers so the springs wouldn't hit them w/ the 5er attached. Tho the truck may squat some, I don't get whammed when the truck goes over a bump and susp is trying to go back down if that makes sense. The suggestion came from posters on here.
That might make it lower if you are on the overloads when it is hooked up, since as you said it will squat more.
But it won't change the unloaded bed height.
Super_Dave wrote:
Are the 3 spacers under the spring pack what can be removed?
