Michelle.S wrote:
Not trying to be a trouble maker or smart a.., but I have to ask a couple of questions regarding changing those rear shackles:
I understand in theory changing to shorter shackles should bring the rear down a bit, but what do you then do with the Rubber Snubbers?  If you lower the back they will be closer to the axle and closer to bottoming out.
Next question, when changing those rear shackles, are you not putting excess stress on the front section of the leaf springs?  It would seem from a mechanical standpoint that the front half would not be carrying more of the load, thus more prone to failure.
Inquiring minds what to know.....
The shackles would be longer (not shorter) to lower the rear.  The snubbers question is a good point. I have about 5 inches clearance with truck not loaded. I will be measuring with trailer connected, thank you. You lost me on the last part of the question.
