Cummins12V98 wrote:
alboy wrote:
JUST rolled into mesquite approx a 1000 miles trip with our 40 ft Landmark on the back of a 2015 Ram dUALLY .4000LB PIN truck is 4000 empty ,tires are Yokohama 245/75/17 e at 55psi.AVG speed 65-72mph,tires run cool and the ride is very nice,rec pressure at 65 is not nice.
"Recommended pressure" is for FULL RAWR. Did you weigh your truck loaded and then use the weight/inflation chart for your rear tires?
There are all kinds of yellow books for dummies,
https://www.dummies.com/, on the list I do not see one for inflating tires correctly! So the wheels of the bus go around and around at max sidewall.
