rangerjeanExplorerMay 29, 2018LP tank sizeThe manufacture states that my 2018 Sonoma has two 20# LP tanks. Does that mean gallons? On the tanks themselves it says 8.5. I am unsure what these numbers mean. At any rate it wasn't enough for a 4 ...Show More
Old-BiscuitExplorer IIIMay 29, 2018New propane cylinders are shipped either with air pressure (100#) or are shipped with a vacuum in them.Ones shipped with vacuum do NOT need to be purged.....they can be directly filled with liquid propaneOnes shipped with air pressure MUST be purged with propane vapor 4-5 times to remove the air then can be filled with liquid propane4 days usage...Two 20# cylindersEither you have a leak or they were NOT properly filledA real propane vendor (bulk supplier) can properly purge them and then fill
Related ContentWhat size waste tank to buy?2012 Georgetown LP Tank SizeLP tankLP Tank Gauge?Down sizing LP tanks and adding scissor jacks
