HoosierDad
May 10, 2021Explorer
lenr wrote:
Had 3 sets of Michelin XLTs before they changed the name to Defender. I found that they had the most road wander of any tire that I've driven to the point that I found them dangerous. Everything else about them was great. On my F-350 the front tires wear off on both edges as if they are under inflated (they're actually over inflated by load.) I am currently running Cooper HT3s because they have a real heavy edges which should help with the wear problem. The ride is a little better than the Continental OEM tires, wear seems good so far, and traction is just as good as the OEMs.
Now that you have a few more months on these HT3s, can you let me know if they have continued to wear well?
I have a second set of Continental Contitracs on my F250 Regular Cab 4x4 with 2,000 miles on them and one or all of them has a problem and is causing a lot of sway pulling a 7,500 Cruiser 29' trailer.
