Troutguy's avatar
Troutguy
LT 285/75R16 Michelin LTX Tires on stock GM Rims
I'd like to hear comments and recommendations from those of you that have put this size tire on your stock GM 2500/3500HD 16" GM wheels.
My 2001 Chevy 2500HD truck is in need of new tires. I currently have Michelin LT 265 75R 16 tires on it now and wanted to upgrade to 285s to increase my load carrying capacity by approx. 350 lbs. per tire. The tire chain that I've dealt with over the last twenty years is refusing to mount 285s on the stock 6.5 in. GM steel wheels as the "wheels are too narrow and should be 7" wide". Another major chain says no problem however I may get some wear on the tire centers using the 6.5" rims, but will still mount them.
I would go to 19.5s however the ones that fit my current truck will not fit GM HD trucks from 2010 and up. So transferring the wheels won't happen if I buy a new truck in the next couple years.
I am well aware of my current overload conditions with either 265s or 285 tires.
I also see that TC Magazine has just started a tire/wheel survey and quite a few TCers are using this same combination.
So let the weight police or the 19.5 fans refrain from starting any arguments please.
Any help will be greatly appreciated.
TG
  • JIMNLIN wrote:
    I tried LT265/75-16 E with a 8" wide tread on a '90 2500 chevy with 6.5" OEM wheels pulling heavy GN trailers. The truck was a handful to keep on the road. So dumped them for the good old LT235/85-16 in the same tire type.
    I had the same experience when I had 265's on the front of my old GM dually. It wandered on the road too much and didn't hold corners like it should.
    I went back to stock size 235's and it steered and handled much better, as expected of a dually.
    I think the rims were 6".
    I'm sure my F350SRW would steer and handle better if I wasn't running 285's on 7" wheels up front. It does OK, but if it had 8" wheels up front, like it has in the rear, steering/handling would be better I bet.
  • If Michelin really requires a 7.5" wheel for that size tire, I think you've found the answer. There should be a spec on the Michigan website to help you.
  • Hi Troutguy:
    Please find below an excerpt from a previous post I made in July of 2012 about LT 285/75R16 Goodyear tires on 16X6.5 inch wide stock GM PYO forged aluminum wheels:
    "My Input: My 2007 GMC 2500HD 4X4 D/A CC has put 43,000 miles on Goodyear Wrangler Silent Armor 285/75R16 tires mounted on the stock PYO forged aluminum wheels. These are all terrain tires with "durawall" side walls to resist cuts and have a load rating of 3750 lbs at 80psi. The Tire Rack sells these tires for $244 each. Bought locally they cost about $280 mounted and balanced before tax. Loaded with the camper wet and all gear, I carry about 4700 lbs on the front wheels and 6500lbs on the rear and travel extensively off-road, as well as on road. I average between 14 and 16 highway MPG on my truck and camper, I now have an average of just over 5/32" of tread left on the tires and project to get at least the 50,000 miles tread life advertised by Goodyear before reaching the wear indicators in the tread."
    I, in fact, did get 50,000 miles out of those tires and then bought another exact same set of tires. My truck was always rock solid with no sway, wandering, bouncing or other uncomfortable handling on the highway (at speeds up to 90 mph - passing) and on gravel and off road trails. I did have to modify my suspension to carry the weight of the camper so I did not get "rock and roll" off road. It is true that the tires do bow up a little in the center, but, for these tires at any rate, this did not significantly affect tire life.
    Based on my experience, 6.5" wide wheels will work just fine with 285/75R16 tires. The problem you will face in going to aftermarket aluminum wheels to get an 8" width is the wheel weight rating seems to top out at 3650 lbs, which is less than the tire weight rating. The stock PYOs can carry about 3800 lbs. Also cast aluminum wheels weigh about 50% more than the forged wheels.
    Hope this helps...Terry
  • Too wide fr the rims is true, but they work. Seen em for years.
    Another easy and cheap option is get some 17" Dodge takeoff rims from the 3rd gen trucks or any of the 17-20" 4th gen rims.
    They fit great on chebbies. I used 17" Dodge Ram takeoff alloys on my 02 Chevy 2500.
    Plus you can buy a set of brand new ram takeoff wheels and tires with 3500lb tires for the same or less than a new set of tires.
  • I'd like to thank all of you that replied on this topic. A lot of great intelligent and thoughtful comments. Well it looks like the majority rules and I purchased a new set of Michelin LT 265 LTX Defender tires from Discount Tire. These are the same size as what I've had on this truck since 2007 and have been happy with them.
    Thanks again for all of your help!
    TG
