jsdad
Jan 25, 2015Explorer
LT or P Tires ?
My old stock Wrangler AT "P" rated 265 70R 17 tires are up for replacement. I know the "LT" are optimum for towing, but was wondering if I really need them? Cost is not a factor between the P and L...
rbpru wrote:I would disagree. I think Ford would too. But regardless if it increases capacity, it can and will increase stability. I know that first hand.
About the only thing you know for sure is the TV manufacturers match the tires to the vehicle's suspension and advertised performance.
If a less expensive tire would meet their performance claims, they would use it. If a more expensive tire would give them an advertising edge over their competitors, they would add them in a heartbeat.
I cannot say that I recall a truck manufacturer offering a "sweet" ride, they all seem fixated on gonzo power, performance and capacity.
If increasing the tire load range, tire size or construction could provide a significant improvment they would have done so.
Does upgrading the tire increase the load bearing capacity of the tire? Yes, does it increase the load bearing capacity of the TV? I doubt it.
