My old stock Wrangler AT "P" rated 265 70R 17 tires are up for replacement. I know the "LT" are optimum for towing, but was wondering if I really need them? Cost is not a factor between the P and L...
Tireman, You make a good point, while a stiffer, wider, even larger tire may have been the solution to one person’s problems, it may make absolutely no difference to another’s.
So when reading these posts, one must keep in mind that they are helpful hints and suggestions, based on solutions to similar situations experienced by others, they are not guaranteed cures to a problem.
