ripperoo
Nov 21, 2013Explorer
Francesca Knowles wrote:Huntindog wrote:
Here is a link to a very good explanation of the govt. testing requirements for each tire type. The actual govt. regs are available, but are difficult and time consuming to research as they keep referring to different sections of the law.
This person did all the work and put this together:
Plain English Testing standards for ST and LT Tires
That so-called "study" gives neither sources nor references of any kind for the information it purports to base its conclusions on. Well, except for nods to other posters here in the Forums. It reads more like a church bulletin than a scientific paper: preaching articles of Faith to The Converted.
Best advice given here came early on: Consult a local tire guy you trust, and buy accordingly.
What was this then?
REFERENCES
The references for my evaluation may be found at the Federal Motor Carrier Safety Administration (FMCSA) webpage:
ST tire standard may be found at FMCSA Part 571, subsection 109.
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?chunkKey=090163348008f295
LT tire standard may be found at FMCSA Part 571, subsection 139.
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?chunkkey=090163348008f2a9
Part 571, subsection 139 references Part 571 subsection 119 which can be found at:
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?chunkKey=090163348008f29d
44,068 PostsLatest Activity: Jun 21, 2026
