Francesca Knowles wrote:
JJBIRISH wrote:
Actually in that situation I might use the P rated over a LT tire…
No kidding- especially given that according to some studies, P-tires are three times safer than LT's- a little known factoid in some crowds.
Here quoting from this NTSB page:
NTSB wrote:
The rate of blowout-caused crashes for light trucks (0.99 percent) is more than three times the rate of those crashes for passenger cars (0.31 percent).
Blowouts cause a much higher proportion of rollover crashes (4.81) than non-rollover crashes (0.28), and more than three times the rate in light trucks (6.88 percent) than in passenger cars (1.87 percent).
Too bad P-tires are so flabby...but there might be some out there that would do the trick.
Well, and part of the problem is that many of the choices in P metrics ( that would have adequate load capacity ) require rim widths that are wider than we typically have on trailers. So yes, "if" we can find a rim wide enough, with zero offset, then we could have some more choices in the P metric lineup.
I was actually being just a bit cheeky in my post above using that K-ho P-metric tire as an example, because truthfully, many trailers that are as light as my funfinder only have a single axle. So "if" mine did have a single axle, then using P metrics on it would be out of the question, as they would be overloaded.
I love my tandem axles...:C
