JJ wrote:
There are no loaded questions used to draw these type of responses from a tire builder… not at all… loaded questions are not needed, only straight honset ones...
Dead wrong again. It does matter how a question is asked regarding what our tire makes say.
You got the answer you were looking for with the Vanco debacle that back fired in your face.
CapriRacer on company liability per Q & A
It totally matters what question you ask and how you ask it.
Using the example above, if I ask: "Is the Vanco2 a suitable replacement for an ST tire, the response would be "No!"" - because the Vanco's are C type tires, not ST type tires and without any additional information, it is not assumed that the question-asker has enough expertise to know that he has to be careful about load carrying capacity and inflation pressure.
But if the question-asker says that he has a trailer with X amount of load on the tires and states that the Y sized Vanco's have more than enough load carrying capacity at the rated inflation, then it is obvious the question-asker has looked at everything pertinent and would get a positive response.
W have email from Michelin/Bridgestone/Goodyear all recommending a particular line of LT tires for our trailer. So for you and FastEagle to say they don't is simply just more usual mis info on your part.
