Lowsuv wrote:
In practical real world solution I think a Goodyear G26 Cargo tire in a size of 225/70R15 is probably as good as available on a 15 inch wheel .
The ST graded 225/75R15D " Marathon " RV tire has a higher sidewall rating .
Goodyear makes them both. They charge more for the Cargo G26 than the ST Tire. The G26 weighs more because it has more cords and rubber.
To argue that the ST tire would be less prone to failure just does not make sense. In the end , if either tire fails it is my expense .
I'm going G26 Cargo over the ST tire if I want to eliminate problems .
I would expect that FE would agree with that .
The G26 Cargo is a commercial grade European designed truck tire.
FE
