SprinklerMan wrote:
Francesca Knowles wrote:
SprinklerMan wrote:
I look at it this way , I havent seen a " LT" tire stamped with anything saying truck use only , or do not use on trailers . BUT I have seen on " ST " tires for "trailer use only"
This makes me wonder are they not made good enough for a truck ?
ST tires are unsuitable for any vehicle's drive/steer axles for exactly the same reason that commercial tires are selected/chosen according to the application:
In both the commercial and private market, trailer tires are designed only to follow a tow- they are not equipped with tread design that will work for drive/steer axles.
Here's a link to a Michelin site for commercial tires that illustrates the difference. You will note that those tires designated for "trailer axles" are NOT named there as suitable for all position or drive axles.
I dont think that tires know whether they are pushing , pulling or following . Tires roll in a circular motion around the axis .
That's where you're mistaken. Tires act as they are designed to do, and "follow" tires like ST's and those designed for Michelin's commercial trailer line do that efficiently.
Would you put racing slicks on the front axles of your street rod? Well, maybe you would. But those folks that understand that the design is
wrong for that position would not.
