CapriRacer wrote:
Francesca Knowles wrote:
JJBIRISH wrote:
Actually in that situation I might use the P rated over a LT tire…
No kidding- especially given that according to some studies, P-tires are three times safer than LT's- a little known factoid in some crowds.
Here quoting from this NTSB page:
NTSB wrote:
The rate of blowout-caused crashes for light trucks (0.99 percent) is more than three times the rate of those crashes for passenger cars (0.31 percent).
Blowouts cause a much higher proportion of rollover crashes (4.81) than non-rollover crashes (0.28), and more than three times the rate in light trucks (6.88 percent) than in passenger cars (1.87 percent).
Too bad P-tires are so flabby...but there might be some out there that would do the trick.
At first, I was going to challenge the statement about the differences in failure rates, but I see that it was attributed - and with a link! Thank you. But I did notice something that doesn't square with my experience in examining failed tires.
The report cited "blowouts" as a key difference between P type tires and LT type tires. Having spent quite a bit of time sorting through failed tires, there are 3 ways the term "blowout" is used:
1) A belt leaving belt separation - which isn't a true "blowout" in the sense that the tire loses inflation pressure as a first cause. In passenger car tires, a belt leaving belt type failure frequently leaves the tire inflated. In LT type tires, less so. But again, the first cause is the separation.
Yes, LT tires are more likely to fail from this than P type tires for 2 reasons:
a) P type tires aren't as intensively loaded - that is, hardly ever are cars loaded to their max - so the likelihood of failure is less.
b) P type tires were what the Ford/Firestone thing was all about (SUV's, too!), so it made sense to address those first. LT tires were addressed later - and this report is dated 2007 using data from 1995 to 1998, so they are using data that would be outdated even at the time they wrote the report. My best guess is that P type tires had gone through 2 iterations of changes by 2007, and LT tires would have gone through 1 iteration.
2) Another usage of the term "blowout" is a road hazard related loss of inflation pressure. LT tires are more likely to experience a puncture because they use higher inflation pressures, which makes the tire stiffer and less enveloping.
3) The last usage of the term "blowout" would refer to a non-road hazard related loss of inflation pressure - and that hardly ever happens. Other than belt leaving belt separations that result in loss of structural integrity, tires rarely have structural integrity issues.
So the report is using some information that will have changed between now and then - AND - I think the report is citing a statistic that is suspect.
Glad somebody commented on this report. As it left me wondering whether I made the right decision in swapping my truck's Ps to LTs.
One of the reasons I switched to LT tires on my truck, in addition to sidewall stiffness, was their possible(?) increased resistance to damage from road debris and potholes. They're heavier and have more belts so should be "stronger", right?
The idea that their increased pressure made them more susceptible to punctures never occurred to me. I only run mine at 48-50psi to match the load rating of the original P's (which I ran at their max 44psi to reduce squirm). But a lot of trucks are running 80psi to get the max weight carrying capacity and stiffest sidewall.
But I agree that LT's will be worked a lot harder and closer to their limits than P's in general, And don't see how you can compare the general population of LTs with Ps without controlling for that difference in usage.
