gmw photos wrote:
I know I said I was done, but a certain line of thought keeps creeping back into this discussion by a certain poster which is misleading at least, and more likely downright incorrect. Sigh.
REFERENCES
The references for my evaluation may be found at the Federal Motor Carrier Safety Administration (FMCSA) webpage:
ST tire standard may be found at FMCSA Part 571, subsection 109.
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?chunkKey=090163348008f295
LT tire standard may be found at http://www.fmcsa.dot.gov/regulations
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?chunkkey=090163348008f2a9
Part 571, subsection 139 references Part 571 subsection 119 which can be found at:
http://www.fmcsa.dot.gov/rules-regulations/administration/fmcsr/fmcsrruletext.aspx?chunkKey=090163348008f29d
Yes, I've seen that quoted before...and well you may sigh. Not a single one of the addresses provided goes to a page where the words quoted can be found. When copied/pasted, they all lead to
this dead end. And simply searching "FMCSA Part 571, subsection 109" does the same thing.
What gives?
