LarryJM
Feb 13, 2020Explorer II
Huntindog wrote:ScottG wrote:Agree. I owned a LOT of Marathons. They all failed in short order. At every replacement, I upgraded size and load range. That TT started out life with 205/14 LRC. the last set of Marathons were 215/15 LRE. All failed. I fell for all the propoganda which was parroted here by many about the NEED to run STs. That 2001 TT ended up with Michelin XPS Ribs in 2006. I have not had a single hint of a tire problem ever since.
The 16" GY Endurance's have been problem free on our TT and negate the need for LT's. However, I hate the co. and would pay 50% more for a similarly performing tire just to avoid them.
When the time comes for new tires, I'll be checking out all the options.
When GY came out with the Endurance, many of the previous ST proponents here rushed out to buy them (in spite of their professed alliegance to the previous STs)
I having already found a solution that worked.... will not buy a tire from a company that repeatadly told how great their previous tires were.... IOW, they cheerfully took thousands of dollars from me selling me junk tires. They no longer deserve any more of my money.
For those of you trying out these new tires.. I wish you luck.
If you start having trouble, you can always go to LTs then.... And tire size upgrades are possible in many cases. That 2001 TT that started out life with 205/14s LRC had 225/16 LREs when I sold it. Yes I had to make a few changes to make the upsized tires work.... But I had so many failures that I needed to do something to stop them. I grew weary of sitting on the side of the road in 110 degrees dealing with tire problems.
Well your single data point on GY Marathon failures is 100% opposite of mine for the last 20+ years of me using exclusively GY Marathon's all the time except for one set of Kumho 857's. I would also say the 100,000's of other trailers out there running on GY Marathon's w/o all of them being on the side of the road due to tire failures seem to support my experience and not yours. As already mentioned when someone has tire issues I tend to believe that something is the root cause other than the tires themselves, usually underinflation, overloading or excessive speed, non of which anyone will ever willingly admit to especially in a public forum. I never had an actual failure with a GY Marathon, but did have two of the Kumho's actually fail (tread separation at under 6K miles). It is also worthy to note that I ran the GYs within 50lbs of their max load rating for the last 10+ years.
With all that being said I did just this year go with a set of GY Endurance tires, but don't have enough experience yet to judge them.
Larry
44,066 PostsLatest Activity: Apr 10, 2026
