rhagfo
Jul 14, 2016Explorer III
mkirsch wrote:Sport45 wrote:
What's your RAWR? Unless it's more than 6390# you won't gain any rated carrying capacity.
Because the factory RAWR is the sum of the capacities of the OEM tires on SRW trucks, it is generally regarded that the effective RAWR is limited by tires, and putting heavier-rated tires increases the effective RAWR.
For example, an early 2000's Chevy 2500 (non-HD) 8600lb GVWR with semi-floating rear axle has a RAWR of 6084lbs, while the same year 2500HD with a 9200lb GVWR and a full-floating rear axle has the SAME RAWR of 6084lbs.
Both trucks run 245/75R16 tires which in a Load Range E have a rating of 3042lbs each. Coincidence? I think not.
If nothing else you gain a greater safety margin!
I looked at the "17" Upgrade" to my 2001 Ram, once I looked at the difference in tire capacity between my OEM 265/75-16E (3,415#) and the 17" 265/70-17E 3,195#, I decided the 16" looking just fine.
44,067 PostsLatest Activity: Jun 05, 2026
