SoCalDesertRid1
Jul 15, 2016Explorer II
It is safe to run nearly anything at or near max load capacity, until it eventually fails.
Better to have too much than not enough, or just barely enough.
A good plan to follow is, if you're running something at greater than about 75% of it's maximum capacity, for greater than about 50% of the time, then you need a bigger something, whatever it is, if you want it to last.
If it's a cheap throw-away, then run it full bore, full time, let it self destruct, and replace it when it's done.
44,067 PostsLatest Activity: Jun 05, 2026
