SoCalDesertRid1
Jul 15, 2016Explorer II
brian91 wrote:I get what you're saying. I think the key there is the 'E' load rating, which is also expressed by a number, like '123', etc. Same size tire in a 'C' or 'D' rating (which also have lower numbers) have lower weight limits.SoCalDesertRider wrote:brian91 wrote:It depends on how the individual brand and model of tire shell is constructed. More plies and/or thicker side walls means greater load capacity, generally.
I wonder who decides on the ratings or how they are determined...
265/75/16 3415 31.7x10.4
265/70/17 3195 31.7x10.4
265/65/18 3306 31.5x10.4
All 3 tires above are the nearly the exact same dimensions, but vary in load capacity.
If you compare all E rated tires, you will notice the same rating across all brands for a given size. I have yet to see an E rated tire with one brand having a higher rating then another. Every 265/75/16E will have a rating of 3415, etc. Correct me if I am wrong but have been looking for higher rated 265/70/17 tire and every brand is 3195, regardless if its a $250 Michelin or a $100 Chinese tire.
In the olden days, 'E' used to mean 10 plies. C and D meant other numbers of plies. Now days, there are not actually 10 plies in an E radial tire, but they are constructed such that they meet a standard that equates to 10 plies.
For the same width and diameter tire, a tire with greater side wall height can hold more air. For otherwise equally constructed tires and equal air pressures, a tire that can hold more air volume, can hold up more weight.
It remains a mystery to me why the 17" tires have unusually low weight ratings, out of step with the other 2 wheel sizes. One would expect them to be half way between the 16" and 18" weight ratings...
44,067 PostsLatest Activity: Jun 05, 2026
