limbery
May 14, 2013Explorer
If you're in Canada, Canadian Tire stores have a spray lubricant specifically for slide seals... you give the rubber a cleaning first to remove any dirt then spray it on....It foams and then you just wipe off the excess foam and spread it evenly over the rubber...I plan on using it once in the spring and then again in the fall...
