Adam_H
Aug 21, 2017Explorer
Downwindtracker2 wrote:
You are dammed if you do and dammed if you don't. The cable if left dry will corrode , crack and break. In a short time I might add. Oh joy. So you have to lubricate it. Motorcycle chain lube works OK. But cable now can pick up dirt. Oh joy.
The cable should be stainless steel so it shouldn't corrode. If you use a dry lube like silicone spray it will not attract dirt like chain lube will.
Adam
44,069 PostsLatest Activity: Jul 06, 2026
