bb_94401's avatar
bb_94401
Macerating pump to empty black/gray tank
In another post Reddog1 said he has be using a macerating pump to empty his tanks at home. This got me thinking that it would give me even more options/opportunities to empty my tanks during winter camping vs. just gravity and the normal hose.
I like the twist-on models that fit onto the drain outlet, that I can install as needed. I've found two different systems, FloJet from Xylem (aka Jabsco) and Sani-con from Thetford. Another company makes a kit using the Flojet pump.
Are you using these models in your TC? Would you do it again? With the same brand? Comments?
Thanks.
